skydiverdriver
Senior Member
- Nov 26, 2001
skydiverdriver said:After negotiating with the Delta MEC, the Comair MEC has agreed to ask thier management to hire furloughed Delta pilots without having to give up their seniority at Delta. This is confirmed on the current Comair VARS message.
I wonder what the Delta pilots plan to do for us in return?
Y'all take 3 years to finally get to it and you want instant reciprocity?? Mabye they need 3 years to think about it....skydiverdriver said:I wonder what the Delta pilots plan to do for us in return?
How about giving more mainline flying and routes away?. DAL can just pull 1 37/80 a month anf turn it over to Mr. and Mrs. RJ to fly.T-Gates said:Y'all take 3 years to finally get to it and you want instant reciprocity?? Mabye they need 3 years to think about it....
How about putting airplanes on routes where they fit best.How about giving more mainline flying and routes away?.
If that is what it takes to get DAL back to it's glory days then by all means they need to do that. They pulled mainline equipment off profitable routes and replaced them with rj's, the mainline planes were going out full most of the time.chperplt said:How about putting airplanes on routes where they fit best.
With your obvious one sided mind, I'm surprised you aren't trying to rally the troops against all the flying Mesa is doing for America West these days...or are you?
I'm sure you would..pretty bad comparison in my opinion.
I've seen a lot of those CRJ-900s in HP colors in and out of LAS every day. What was on those routes before the 900? Were they using a Dash on the LAS-SNA route before? Must be cheaper to run those than the old 73s you guys have.Mesa is a "feeder" as Comair is to DAL. Mesa is not overtaking HP routes nor is the larger equipment being threatened
How do you know what routes are profitable? Just because the plane is full does not mean the flight is profitable.350DRIVER said:If that is what it takes to get DAL back to it's glory days then by all means they need to do that. They pulled mainline equipment off profitable routes and replaced them with rj's, the mainline planes were going out full most of the time.
