What's the scoop on this... saw Delta is using 1900's out of JFK in Sept. to PVD.... any other routes? Is this a permanent thing or did Mesa just run out of Dash 8's to make available to Freedom?
Delta website states that flights with Air Midwest begin August 15th, however nobody here has been notified of this. Im sure it will be a smooooth start...
Something is VERY VERY WRONG. Next is going to be CRJ's because Delta will get every other type of equipment that Mesa operates besides Dash 8's. They can't get the airplanes up and running for the Dash 8 operation....they have a couple of hundred pilots waiting around, most haven't touched an airplane since their checkride months ago waiting on the airplanes to arrive....it's so much fun, especially when they start talking consolidation problems.
One FAA inspector plus one DASH 8 divided by JFK ramp equals 58 write ups aircraft grounded indefinately.But thats not the best part should the 1900s not prove up to snuff JOs considering hot air balloons on JFK..PVD route.
